914bub |
Member ![]() ![]() Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None ![]() |
After waiting 2 years to get my car to me,and another year sorting issues, replacing the clutch etc. I'm down to needing first gear. I have 2nd through 5th and reverse. I've read every thread I can find about shifter adjustment. Most pertain to side shifter transmissions but usually say that the process is similar, just different adjustment points for a tail shifter.
Can anybody tell me how to get 1st gear? Unlike other cars I've owned, it grinds when trying to get into first. The other cars I've owned might grind but you could "push past" the grind and jamb it into gear.It's almost like there isn't enough shifter throw to get it into 1st gear. I've replaced the ball cup bushing at the base of the shifter and have all the other bushings to replace the whole set. I've inspected the others and they don't seem wasted. I've tried putting it into first before starting the car and it's the same issue. Shifter doesn't have enough throw..... (IMG:style_emoticons/default/WTF.gif) Any help would be greatly appreciated. |
914bub |
Thanks for all the responses. I haven't been grinding 1st gear for an extended period of time, just enough to try and test drive it. I've only driven the car a 1/2 mile since I've owned it. The clutch is new and is adjusted correctly. I think it's time to chuck the tail shifter and upgrade to a side shift transmission. I called a friend and he has 2 pf them so I'll be picking them up on the 26th. I have everything for a conversion except the shifter.
Thanks again,you guys are so helpful......I love "the world"! |
Lo-Fi Version | Time is now: 24th June 2024 - 07:27 AM |
