> Experience with the HF Scissor Lift, (merged)
DMCF1Fast
post Dec 13 2014, 08:31 AM
I'm thinking about getting this lift from Harbor Freight and wanted to know if the adjustments for the jacking pads fit 914s and 911s well? I think I saw some people had this lift on here a while back but can't find the posts when I search. Also if you have experience with this lift did you like it?
http://t.harborfreight.com/6000-lb-capacit...lift-91315.html
Elliot Cannon
post Dec 13 2014, 11:37 AM
Group: Retired Members
The scissor lifts are almost all identical. I believe they are assembled by the same group of teenagers somewhere in China. I have used mine a lot for the past five years or so and it works great. Having said that, I NEVER get under it without some kind of safety device (big jack stands) other than the mechanical lock in the lift or the beach chair on casters that I sit on. (IMG:style_emoticons/default/biggrin.gif) Maybe I'm over cautious but I don't think that's really possible.
Tom_T
post Dec 13 2014, 12:41 PM
TMI....
QUOTE(Elliot Cannon @ Dec 13 2014, 09:37 AM) *
(IMG:http://www.914world.com/bbs2/uploads/post-7407-1418492211.jpg)
Hmmmm .... (IMG:style_emoticons/default/idea.gif) .... That may be a solution for our tiny 17'-6" w x 18'-0" L (outside) x 7'-6" ceiling ht. 1921 "Model T" garage.
However, doesn't the idea of using jack stands + a scissors lift defeat the purpose of using a lift vs. good floor jack & jack stands?? (IMG:style_emoticons/default/confused24.gif)
Elliot Cannon
post Dec 13 2014, 06:33 PM
QUOTE(Tom_T @ Dec 13 2014, 10:41 AM) *
The scissor lift will hold the car up higher than floor jacks and jack stands. I put two jack stands under the lift in case the hydraulic pressure fails then the mechanical lock fails. If both those things happen (not likely) the lift will stop at the jack stands and save my old ass from being crushed. It's a belt and suspenders kinda thing. By the way, my "garage" is an enclosed car-port. The floor is 17X17.5 with a seven foot ceiling. (IMG:style_emoticons/default/biggrin.gif)
Tom_T
post Dec 14 2014, 07:08 PM
TMI....
QUOTE(Elliot Cannon @ Dec 13 2014, 04:33 PM) *
Would that be a Red-Green Show sort of belt & suspenders Elliot? (IMG:style_emoticons/default/laugh.gif)
I get what you mean though, but I thought you meant a set of those +/- 48-60" tall jack stands.
Otherwise, I'd think that the extra force from the drop if the scissors jack failed, might either kick out the short jack stands or crush then from the momentum of the drop down.
Your carport/garage is about the same size as mine, so I think it will work without my having to "raise the roof".
Thanx! (IMG:style_emoticons/default/beerchug.gif)
Tom
DMCF1Fast   Experience with the HF Scissor Lift   Dec 13 2014, 08:31 AM
r_towle   You may not get many responses.....the former owne...   Dec 13 2014, 08:36 AM
Garold Shaffer   You may not get many responses.....the former own...   Dec 13 2014, 08:46 AM
3d914   You may not get many responses.....the former ow...   Dec 18 2014, 12:01 PM
Garold Shaffer   [quote name='Garold Shaffer' post='2121933' date=...   Dec 28 2014, 09:50 AM
DMCF1Fast   You may not get many responses.....the former own...   Dec 13 2014, 09:12 AM
rhodyguy   You might have better luck with Greg Smith Equipme...   Dec 13 2014, 08:44 AM
DMCF1Fast   You might have better luck with Greg Smith Equipm...   Dec 13 2014, 08:56 AM
r_towle   What I meant... :) Got my four poster there, part...   Dec 13 2014, 08:45 AM
DMCF1Fast   Thanks, the Atlas one looks better and is 110v whi...   Dec 13 2014, 08:52 AM
Mueller   No personal experience, however a quick search and...   Dec 13 2014, 08:54 AM
r_towle   No personal experience, however a quick search an...   Dec 13 2014, 08:58 AM
rhodyguy   I'm going to buy one of their 2 post lifts aft...   Dec 13 2014, 08:54 AM
DMCF1Fast   I'm going to buy one of their 2 post lifts af...   Dec 13 2014, 08:59 AM
rhodyguy   I used a cousin's 4 post when adjusting the va...   Dec 13 2014, 09:03 AM
mepstein   I have really great neighbors He'll get a ring...   Dec 13 2014, 09:05 AM
rhodyguy   Too old to risk injury over a couple of hundred bu...   Dec 13 2014, 09:09 AM
DMCF1Fast   Too old to risk injury over a couple of hundred b...   Dec 13 2014, 09:20 AM
rdgabert   I also looked at the HF scissor lift but ended up ...   Dec 13 2014, 10:09 AM
Highland   After reading this thread I feel kinda bad buying ...   Dec 13 2014, 10:23 AM
ConeDodger   I bought a HF scissors lift from another member wh...   Dec 13 2014, 10:54 AM
GeorgeRud   I think HF is just a distributor for a bunch of Ch...   Dec 13 2014, 11:21 AM
Elliot Cannon   The scissor lifts are almost all identical. I bel...   Dec 13 2014, 11:37 AM
Tom_T   The scissor lifts are almost all identical. I be...   Dec 13 2014, 12:41 PM
Elliot Cannon   The scissor lifts are almost all identical. I b...   Dec 13 2014, 06:33 PM
Tom_T   [quote name='Tom_T' post='2122022' date='Dec 13 2...   Dec 14 2014, 07:08 PM
mepstein   Extra safety under the car is always a no brainer....   Dec 13 2014, 12:17 PM
fiid   I have one similar to this from Greg Smith. http:...   Dec 13 2014, 03:16 PM
mr2by4   I have an off brand scissor lift. I bought it used...   Dec 13 2014, 06:53 PM
patssle   Occasionally the lift is in the way. VERY in the ...   Dec 13 2014, 07:28 PM
mr2by4   Occasionally the lift is in the way. VERY in the...   Dec 13 2014, 08:22 PM
fiid   It doesn't seem to move the car much. It...   Dec 24 2014, 01:12 PM
PancakePorsche   The HF lift you refer to is a exact copy of my Ben...   Dec 27 2014, 11:43 PM
Amphicar770   I have a SnapOn, made by Wheeltronic, lift that I ...   Jan 7 2015, 07:59 PM
billh1963   I bought one of these a couple of months ago. Got ...   Jan 8 2015, 06:54 AM
BK911   I have the HF scissor lift. No problems during doz...   Jan 8 2015, 07:22 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 08:45 PM
