OU8AVW |
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region ![]() |
I'm working through starting my freshly rebuilt 2056. It has the original D-Jet and is a 1975 motor. At first I had no fuel pump, I fixed that.
Now there is no spark from the coil. I traced the lead from #8 on the fuse box to the relay board then out the relay board. I have 12.4v at the coil positive but no spark. I'm testing it with a light-type tester. No bueno.... It is a Bosch coil, i believe it is a "blue" coil. I read here that there should be 1.5 ohms resistance between the two poles on the coil with everything dissconnected. This one tests at 7.4 ohms. A spare coil I had had similar results with no spark at crank and 4.6 ohms resistance. I assume i need a new coil...... Right? |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:37 PM |
