Engine start up, Problem 3: Weak Starter |
OU8AVW |
Dec 17 2014, 11:44 AM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
I'm working through starting my freshly rebuilt 2056. It has the original D-Jet and is a 1975 motor. At first I had no fuel pump, I fixed that.
Now there is no spark from the coil. I traced the lead from #8 on the fuse box to the relay board then out the relay board. I have 12.4v at the coil positive but no spark. I'm testing it with a light-type tester. No bueno.... It is a Bosch coil, i believe it is a "blue" coil. I read here that there should be 1.5 ohms resistance between the two poles on the coil with everything dissconnected. This one tests at 7.4 ohms. A spare coil I had had similar results with no spark at crank and 4.6 ohms resistance. I assume i need a new coil...... Right? |
OU8AVW |
Dec 19 2014, 01:26 PM
Got spark. It was the points
Fuel pump seems to be working. I'm thinking that my starter isn't giving me enough umph. I used my old ground strap because I couldn't find the new one I had purchased. That's my first step to try. A new new one is on the way. Anyone have a diagram of how this starter should be wired? I have a solenoid installed. The starter turns the motor but not very fast. Looks like a rebuilt unit. Nice and clean. You guys are awesome. Note: my fuel pump has been relocated under the tank, above the steering rack. |
Lo-Fi Version | Time is now: 24th September 2024 - 12:53 PM |
