OU8AVW |
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region ![]() |
Next step for me is setting up my valve train geometry. I searched the web and the World and now I have enough information to know that I need more information. I see a few references to an article Jake had on his now extinct forums. The Facebook page is pretty vast. Can someone point me to this article? I think that's my first step toward comming up with more intelegent questions.
FYI: I'm building a 2056 based on a late case. I have Jake's 9550 cam installed I have swivel feet adjusters mounted on 1.7 rockers with solid spacers I am using SS valves and chromoloy push rods I installed 8x10 rocker studs I have used .065" of shim on the cylinders with no head gasket Thanks! (IMG:style_emoticons/default/piratenanner.gif) |
OU8AVW |
I realized i forgot to post the final numbers on this thread.
I dialed in my angle of attack per Krustie's advice and got down to sorting the geometry. I did use a set of shims. I also had to cut the adjusters to clear the valve covers. Final lift was .001" off. Well within the +/- 5% ![]() |
Lo-Fi Version | Time is now: 15th March 2025 - 02:55 AM |
