Car has spark! My suby setup, Now just dbl checking all wires to be sure load are good before running |
JRust |
Dec 21 2014, 12:00 PM
914 Guru Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay so my wrench called last night. Car was all finished & he went to fire it up. Turns over fine but no start. This is what it was doing before the fire. Also off & on it has plagued me since I got the car. I've replaced the ignition with multiple times. I added a push button for the starter to take that off the switch. Seemed like there was to much power going through it which I thought was from the starter. Obviously it is not.
One thing is almost without fail as soon as I put in a new switch & use it I get smoke from it every time. It would be fine right after the brief smoke so I didnt worry to much about it. What else is feeding the ignition switch that may be pushing to much power through it? What do you guys recommend doing here? Cutting out the switch completely? Do you think the problem lies somewhere besides the switch? |
rhodyguy |
Dec 21 2014, 02:22 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,113 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
jamie, have you spoken with the p.o. as to whether he experienced this current problem? did you make any alterations or add anything to the electrical system post purchase?
Lo-Fi Version | Time is now: 25th June 2024 - 04:44 PM |
