Sloppy shifter, how do you finally fix this? |
brooks944 |
Dec 21 2014, 03:48 PM
Member Group: Members Posts: 248 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
I can move my shifter quite a bit in every direction. Already tried the JB weld fix a couple of times but it still gets loose. I don't have a welder, what is the next best way to fix this?
Thanks, Rick |
Wdunster |
Dec 23 2014, 10:15 AM
Panel beater Group: Members Posts: 172 Joined: 10-June 14 From: Monroe,nc Member No.: 17,469 Region Association: South East States |
One solution I found is to utilize an old steering shaft. Take the u-joint off to use at the shaft coming out of the firewall. It uses the same diameter shaft. You will need to cut a slot in the shaft for the sinch bolt. On the shift rod itself you will weld the spline portion onto the end after removing the joint. Once I did this my shifter was much more precise.
Attached image(s) |
Lo-Fi Version | Time is now: 6th January 2025 - 08:42 PM |
