r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
On the low boost setting, the 5.0L V8 makes 680hp (507kW) and 920Nm at the rear wheels. For a 1,150kg car, that’s plenty enough power, and Finn Arne admits that it can be a real handful at times.
Your favorite motor. http://www.speedhunters.com/2014/09/twin-t...-monster-inside |
Maltese Falcon |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,728 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
Carl over at 928 Motorsports is a guru on all things 928; force fed, 6.0L stokers, Salt Flats world record holder, Pike Peak.
He is a long time believer in these engines , and MSDS headers are run on all of his hot rod engines. Rick (alien) has a 928 for power in his black gt (IMG:style_emoticons/default/driving.gif) These engines do need the dry sump though, in high g-loading turns. Marty |
r_towle |
Carl over at 928 Motorsports is a guru on all things 928; force fed, 6.0L stokers, Salt Flats world record holder, Pike Peak. He is a long time believer in these engines , and MSDS headers are run on all of his hot rod engines. Rick (alien) has a 928 for power in his black gt (IMG:style_emoticons/default/driving.gif) These engines do need the dry sump though, in high g-loading turns. Marty Marty, What are you doing for fuel and ignition on your beast? |
Lo-Fi Version | Time is now: 26th June 2024 - 09:38 AM |
