Weird (?) Dyno Results, 4-banger, Can this be legit? |
MikeInMunich |
Jan 1 2015, 07:48 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Can a few of you veterans out there please offer feedback regarding this dynograph?
This is new to me, but I am skeptical here. (IMG:style_emoticons/default/confused24.gif) Thanks! Mike in Munich Attached thumbnail(s) |
MrLeeS |
Jan 1 2015, 10:19 PM
Member Group: Members Posts: 62 Joined: 25-April 09 From: Albuquerque, NM Member No.: 10,300 Region Association: Southwest Region |
Data logging the run should be standard nowadays. I had a chassis dyno in my shop for 3 years and always ran a wideband just to give the customer something useful from their runs. First thing I'd look at in your case is the throttle and make sure it's opening all of the way. Your graph is a classic example of not enough air flow. And at 2 liters this smaller valves heads shouldn't be pulling you down that much at the top end.
Also, it is obvious the Tourqe and hp are headed for the 5250 intersection, if you can get there. Good luck. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:22 AM |
