ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
So, I got the alternator installed on Betty's car. No more sudden brief cutout. But now I ended up with a dead hole. #4 is stone dead. Tested the injection with a noid light, and it is firing. Replaced all 4 plugs and the wire on the dead hole, and it still is misfiring.
Pulled the injector and ohm tested it. Open circuit on the coil. (IMG:style_emoticons/default/headbang.gif) I can't catch a break! Anyone have a 912E injector for sale? I use them to put some additional fuel into the system to compensate for the "slightly" modified 1.8 engine. |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Not sure why you think the 912E injectors pump out more juice, same as the stock 1.8L injectors:
Attached image(s) ![]() |
ClayPerrine |
Not sure why you think the 912E injectors pump out more juice, same as the stock 1.8L injectors: Jeff, The 1.8 injectors are 022 906 031 A, which was superseded by 022 906 031 C injectors. These are white injectors. The 76 912E injectors are 923 606 109 00, which are green injectors. They are the same as a 2.0 Bus with L-Jet. They do flow a little bit more fuel, and that helps with the slightly massaged engine in Betty's car. A local 914 guy found some of the proper injectors for me. So I have a pair of used ones now. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:26 PM |
