ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
So, I got the alternator installed on Betty's car. No more sudden brief cutout. But now I ended up with a dead hole. #4 is stone dead. Tested the injection with a noid light, and it is firing. Replaced all 4 plugs and the wire on the dead hole, and it still is misfiring.
Pulled the injector and ohm tested it. Open circuit on the coil. (IMG:style_emoticons/default/headbang.gif) I can't catch a break! Anyone have a 912E injector for sale? I use them to put some additional fuel into the system to compensate for the "slightly" modified 1.8 engine. |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Bosch makes injectors for many different vehicle brands, using one Bosch PN. Different car manufacturers assign their part numbers to the Bosch part which is why one Bosch PN may = several different vehicle PNs. Sometimes the different Bosch numbers are for subtle reasons - harder pintles, short hose, curved hose etc. But the injector body and performance are otherwise the same. Bosch catalogs show their injectors (and other parts), then shows the different applications to different vehicles.
Lo-Fi Version | Time is now: 25th June 2024 - 08:08 PM |
