DavidSweden |
Member ![]() ![]() Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia ![]() |
I am rebuilding my engine a 2.0 from 76. I took the heads in to be reconditioned.
The machinist told me that the valve stems needed replacing, the valves needed regrinding and the seats machined. He said this would be no problem. He know tells me that the new valve stems are not at the same angle as the originals and after machining the seats the valves sit too low in the valve seats. He says new valve seats are required As you will understand I am not happy especially when he reassured me that he could do the job no problem. Is this guy incompetent dick head or is this a common problem,? Appreciate feed back before I go to the shop on Wednesday. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
If he put in new valve guides and reamed them out at the wrong angle, then tried to fix his error (he jigged it up wrong) by grinding the valve seats again, I would have to agree.....go get your heads.
Now you need new guides, again, and new seats. It's not the end of the world and the heads are not ruined, you may just want to find a shop the knows how to deal with type4 heads. Contact mittelmotor in Germany, they may be able to suggest a good machinist in Sweden, or look at the german look forum on,shoptalk forums and ask there...again to get a name of a shop that will treat you right. |
Lo-Fi Version | Time is now: 26th June 2024 - 10:00 AM |
