A/C on a 3.2 Conversion, Building an A/C system |
McMark |
Jan 5 2015, 09:13 PM
We're doing an A/C install on a 3.2 project car and I though ya'll might like to see how it goes.
First I made a rough mockup of the location to test fit the setup in the car. This is just a TINY bit too high. I need to move it down and outwards a bit to clear things. Once I had the general location I started making paper templates of the mount. It's a bit like putting together a puzzle, but instead of finding where pieces go, you just make your own as you go along. This will be made out of 1/8" plate most likely. The three circles you see will be bolts. The mount will be two pieces -- one underneath the tin and one on top. The tin will be sandwiched in between the two. Oh man. How do I STILL not have a CNC plasma cutter. (IMG:style_emoticons/default/headbang.gif) |
jeeperjohn56 |
Jan 5 2015, 11:30 PM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Mark, when you get this figured out give me a call and let me know what the cost will be. what kind of condenser are you using?would the stock one up front work? let me know when you get it worked out. John
Lo-Fi Version | Time is now: 20th June 2024 - 05:35 AM |
