engine hesitation issues |
rosenfe |
Jan 5 2015, 08:38 PM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
my 73 2.0 started hesitating just this week when i rev at end of 1,2,3 gear,acts as though its not getting fuel,and it will just die if i come to an stop.i can get it started again,but it takes a bit of cranking. it will then run well and i have to keep revs up to avoid it dying at a stop .i changed fuel filters,have not changed tank sock.fuel pump is running.it has 2- 34 carbs, fairly new..
is this enough info to get some opinions.i wonder if either the fuel sock is full of crap or fuel pump is bad.it too is fairly new. |
rhodyguy |
Jan 6 2015, 10:33 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Rotary or facet pump? I think you might be able to replace the sock with the tank in but pulling the tank isn't that big of a chore. Great opportunity to get the tank nice and clean. Use the fp to empty the tank and look down the fill neck with a flashlight while the tank is still in place. Typically the sock gets sucked flat when it's all gummed up and under vacuum. The vacuum eases when the pump isn't running and may allow some fuel to exit the tank.
Lo-Fi Version | Time is now: 28th June 2024 - 01:04 PM |
