rosenfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None ![]() |
my 73 2.0 started hesitating just this week when i rev at end of 1,2,3 gear,acts as though its not getting fuel,and it will just die if i come to an stop.i can get it started again,but it takes a bit of cranking. it will then run well and i have to keep revs up to avoid it dying at a stop .i changed fuel filters,have not changed tank sock.fuel pump is running.it has 2- 34 carbs, fairly new..
is this enough info to get some opinions.i wonder if either the fuel sock is full of crap or fuel pump is bad.it too is fairly new. |
rosenfe |
viweing from above sock is not flat..i will have it out today or tommorow,but i did find crap in the copper pipe attched to sock side of tank.as you said, im starting at tank,if problem persists i will change out fuel pump.it certainly cant hurt to change sock.
Lo-Fi Version | Time is now: 28th June 2024 - 12:44 PM |
