Heat Exchangers, can any maintenance be done? (YES: updated) |
malcolm2 |
Jan 6 2015, 09:17 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I am preparing to send Dr Evil a patient, my crunchy, grindy trans. I decide to remove the exhaust and the HEs to give me some room.
The HEs are complete, but they do have some loose rusty areas. Mainly at the fan end. Even a hole in one where the axle dimple is. The welds on both ends are loose or broken. I am probably losing some heat efficiency. if there is such a thing. (IMG:style_emoticons/default/blink.gif) Is there anything that I can do while the trans is gone to close up some holes and tighten up the seams? I found some repair tape made for this sort of thing. I used another similar product on my 85 VW Cabriolet. I cut up a coke can and patched the hole, then wrapped it in the heat sensitive material. Once the muffler got hot it all sealed up. Anyone do anything to these old exhausts and HEs? dealing with a '75 BTW. Thanks, Clark |
rhodyguy |
Jan 7 2015, 10:17 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,192 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you will need to covert to the earlier ducting system. those darned accountants get in the way every time. the 1.7/1.8 and 2.0 he's will bolt right up.
malcolm2 |
Jan 7 2015, 11:21 AM
you will need to covert to the earlier ducting system. those darned accountants get in the way every time. the 1.7/1.8 and 2.0 he's will bolt right up. I've been practicing my "searching" and found lots of old ads with pictures. (IMG:style_emoticons/default/piratenanner.gif) did I get it right? It looks like the 2.0 HEs have shorter and "flatter" pipes from the HE to the muffler flange. Is that the difference? Then comes the diffs with the muffler, I guess. Am I missing any other diffs? |
Lo-Fi Version | Time is now: 31st October 2024 - 07:25 PM |
