> What kind of calipers are these?
tornik550
post Jan 7 2015, 01:31 PM
These are from a 911 however I do not know the year. I think it was somewhere in the 80's. What kind of caliper are they. If I am going to use them (I have a 911 suspension) what rotors do I buy?
Eric_Shea
post Jan 7 2015, 03:25 PM
PMB Performance
11mm thick spacers = Carrera or "Wide A-Caliper"
48mm cup style piston
3.5" Mounting ear spacing
Uber Heavy 9lbs. 6oz. without pads etc.
Uber heavy 24mm rotating mass flywheel associated with them (better known as more brake rotor than any 914 will ever need) (IMG:style_emoticons/default/biggrin.gif)
Same FMSI D45 pad size for all A-Caliper species.
tornik550   What kind of calipers are these?   Jan 7 2015, 01:31 PM
rhodyguy   Just went thru this. Measure the bolt hole spacing...   Jan 7 2015, 01:36 PM
tornik550   3.5" bolt hole spacing 1cm middle caliper spa...   Jan 7 2015, 02:01 PM
SLITS   Spacer between halves are either 7 mm or 10 mm as ...   Jan 7 2015, 02:27 PM
tornik550   Spacer between halves are either 7 mm or 10 mm as...   Jan 7 2015, 02:32 PM
SLITS   20 mm = 911SC calipers .. called "A" cal...   Jan 7 2015, 02:53 PM
rhodyguy   yes, they are 1 cm thick.   Jan 7 2015, 03:14 PM
Eric_Shea   11mm thick spacers = Carrera or "Wide A-Calip...   Jan 7 2015, 03:25 PM
colingreene   Could you take the spacer out and run the more nar...   Jan 7 2015, 05:35 PM
bdstone914   Could you take the spacer out and run the more na...   Jan 7 2015, 05:52 PM
Eric_Shea   Could you take the spacer out and run the more na...   Jan 8 2015, 09:36 AM
colingreene   isent the solid rotor what you want for a 914, sin...   Jan 7 2015, 06:02 PM
falcor75   Better brakes allows you to brake later....but for...   Jan 8 2015, 05:18 AM
brant   Better pads and tires allow you to brake later. S...   Jan 8 2015, 06:57 AM
tornik550   The "wide A" calipers came with a front ...   Jan 8 2015, 09:43 AM
Eric_Shea   Nope. ;) Rotors etc. shipping today out of Harri...   Jan 8 2015, 11:55 AM
colingreene   I would say no, its just not the optimal high perf...   Jan 8 2015, 11:55 AM
stugray   The fastest 914 at the track has 5 lug conversions...   Jan 8 2015, 01:39 PM
colingreene   That makes sense, its a problem i run into in the ...   Jan 8 2015, 03:23 PM
- Lo-Fi Version Time is now: 6th January 2025 - 03:27 PM
