> What kind of calipers are these?
tornik550
post Jan 7 2015, 01:31 PM
These are from a 911 however I do not know the year. I think it was somewhere in the 80's. What kind of caliper are they. If I am going to use them (I have a 911 suspension) what rotors do I buy?
Eric_Shea
post Jan 8 2015, 11:55 AM
PMB Performance
Nope. (IMG:style_emoticons/default/wink.gif)
Rotors etc. shipping today out of Harrisburg. (IMG:style_emoticons/default/thumb3d.gif)
FYI... you now have the same basic pad size and the same pistons as those Brembos you had.
tornik550   What kind of calipers are these?   Jan 7 2015, 01:31 PM
rhodyguy   Just went thru this. Measure the bolt hole spacing...   Jan 7 2015, 01:36 PM
tornik550   3.5" bolt hole spacing 1cm middle caliper spa...   Jan 7 2015, 02:01 PM
SLITS   Spacer between halves are either 7 mm or 10 mm as ...   Jan 7 2015, 02:27 PM
tornik550   Spacer between halves are either 7 mm or 10 mm as...   Jan 7 2015, 02:32 PM
SLITS   20 mm = 911SC calipers .. called "A" cal...   Jan 7 2015, 02:53 PM
rhodyguy   yes, they are 1 cm thick.   Jan 7 2015, 03:14 PM
Eric_Shea   11mm thick spacers = Carrera or "Wide A-Calip...   Jan 7 2015, 03:25 PM
colingreene   Could you take the spacer out and run the more nar...   Jan 7 2015, 05:35 PM
bdstone914   Could you take the spacer out and run the more na...   Jan 7 2015, 05:52 PM
Eric_Shea   Could you take the spacer out and run the more na...   Jan 8 2015, 09:36 AM
colingreene   isent the solid rotor what you want for a 914, sin...   Jan 7 2015, 06:02 PM
falcor75   Better brakes allows you to brake later....but for...   Jan 8 2015, 05:18 AM
brant   Better pads and tires allow you to brake later. S...   Jan 8 2015, 06:57 AM
tornik550   The "wide A" calipers came with a front ...   Jan 8 2015, 09:43 AM
Eric_Shea   Nope. ;) Rotors etc. shipping today out of Harri...   Jan 8 2015, 11:55 AM
colingreene   I would say no, its just not the optimal high perf...   Jan 8 2015, 11:55 AM
stugray   The fastest 914 at the track has 5 lug conversions...   Jan 8 2015, 01:39 PM
colingreene   That makes sense, its a problem i run into in the ...   Jan 8 2015, 03:23 PM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 03:40 PM
