McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
We're doing an A/C install on a 3.2 project car and I though ya'll might like to see how it goes.
First I made a rough mockup of the location to test fit the setup in the car. This is just a TINY bit too high. I need to move it down and outwards a bit to clear things. ![]() ![]() ![]() Once I had the general location I started making paper templates of the mount. It's a bit like putting together a puzzle, but instead of finding where pieces go, you just make your own as you go along. This will be made out of 1/8" plate most likely. The three circles you see will be bolts. The mount will be two pieces -- one underneath the tin and one on top. The tin will be sandwiched in between the two. ![]() ![]() ![]() Oh man. How do I STILL not have a CNC plasma cutter. (IMG:style_emoticons/default/headbang.gif) |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Great looking! I think you may have finally come up with a workable solution for properly mounting an AC compressor on a 914-6. Have you checked whether the compressor location will allow you to swap out the oil filter on the oil tank with the AC compressor mounted? Worse comes to worse, it should be easy enough to move out of the way if needed for servicing, and should actually end up with better access to components than in a 911.
Lo-Fi Version | Time is now: 20th June 2024 - 06:04 AM |
