!SOLD! Modified Rear Swing Arms & Shea 5 Lug Hubs & more !SOLD! |
pnewman |
Jan 8 2015, 10:29 AM
Member Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
SOLD!
Used 5 lug hub conversions that were made by Eric Shea Not used since rebuilding: Rear Swing Arms : Tubed Also reinforced at pivot / tube joint Towing loops welded on grease fittings installed (in case you choose to use bushings that would require lube.) Towing loops welded for J hooks Powder coated Cadmium plated: rear pivots / shafts bearing retainers , bolts and washers 10 Studs 2 Brake Clips I am throwing in a set of Poly Graphite bushings (One of the bushings had some filing work done to one end. I don't think that it will effect the performance but thought it only fair to mention.) SOLD! Pete Attached image(s) |
pnewman |
Jan 10 2015, 05:51 PM
SOLD!
Lo-Fi Version | Time is now: 2nd February 2025 - 06:57 AM |
