New Suby build on my old v8 car- Change of plans, Selling this car to a buddy. The WRX motor will be going in my green 914 |
JRust |
Jan 10 2015, 02:39 PM
914 Guru Group: Members Posts: 6,313 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I've put this car off long enough. I am buying a 2004 WRX motor to put in. As well as a suby tranny. I plan to get everything up & driving in this car. Then swap the drivetrains with my green car. We'll see how that plays out.
I need to replace the firewall section that was cut out by the PO in the late 80's. I'm going to replace the lower cutout of the firewall first. I like the idea of making the upper section of the firewall removable. Nice to have access from the front if possible. At least while I am getting it all setup. If I don't feel the need later I'll just make the firewall stock. I've got the 911 rear axles already so will need to get those resplined for the suby CV tranny side. I've got the suby tranny I'm buying from Bob. I plan to do my motor cradle mount a little different. Not really planning on a cradle. I'll draw something up on it & post it later. Basically will use the engine bar mounts. But I plan to have an bar arch to the firewall where there will be another mount but a sideways tube. So there would be three mount points on the bar. the typical spots for the engine bar. Plus the front mount which will pivot. So when bolting in the drivetrain. You would get the front of the motor up first. Then lift the tranny up & bolt in place. Then the engine bar mounts. This will keep everything nice & out of the way for the exhaust. I came up with this thinking of the Porsche 6 firewall mounts. Anyway it will make more sense with a picture. For the WRX motor. It has the Stock ECU with wiring setup for a 914 with the ECU flashed. Not sure if I'll be keeping that setup or using my spare Stinger ECU. Motor has a round 55k on it. I plan to do the timing chain & head gaskets while it's out. I'm also looking into getting bigger injectors, Fuel Rail & bigger turbo. I may wait on that but getting all my options of upgrades before it goes in. My plan is for this motor to go in my green car eventually. I'm going to get it all up & running in my old v8 car. Then make the decision to swap it. Then my old car will get sold. Well there is the start of the plan. I'll update as things come in Attached thumbnail(s) |
PanelBilly |
Jan 11 2015, 12:20 PM
914 Guru Group: Members Posts: 5,865 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Not trying to be critical here, but have you thought about buying a 4 wd suby and driving the whole package the way they built it?
Mueller |
Jan 11 2015, 01:59 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Not trying to be critical here, but have you thought about buying a 4 wd suby and driving the whole package the way they built it? One could argue that the Porsche never intended people to put a 911 3.6 or even 2.7l six in a 914 since Ferdinand Porsche once said he wished he had made the /6 smaller since he didn't care for how they kept increasing the bore and stroke making it bigger and bigger each model year. Back to the original thread.... Why are you ditching the V8? |
Lo-Fi Version | Time is now: 6th January 2025 - 09:05 PM |
