MikeInMunich |
Member ![]() ![]() Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None ![]() |
Can a few of you veterans out there please offer feedback regarding this dynograph?
This is new to me, but I am skeptical here. (IMG:style_emoticons/default/confused24.gif) Thanks! Mike in Munich Attached thumbnail(s) ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
95 DIN HP is stock for a 2.0 motor. I forget if that's what you have or not.
The lines do not intersect at 5250 RPM because the torque and power are using different scales. The line showing 30 HP, for instance, is at about 43 lb-ft of torque. --DD |
MikeInMunich |
95 DIN HP is stock for a 2.0 motor. I forget if that's what you have or not. The lines do not intersect at 5250 RPM because the torque and power are using different scales. The line showing 30 HP, for instance, is at about 43 lb-ft of torque. --DD Thanks Dave. The engine is a 1.8 with stock cam and heads. P&Cs are 96 mm. Not sure if the displacement is 1971 or 2056 as I am not sure of what the stroke of this crank is. Only the P&Cs were changed. The car has headers. M.i.M. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:49 AM |
