MikeInMunich |
Member ![]() ![]() Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None ![]() |
Can a few of you veterans out there please offer feedback regarding this dynograph?
This is new to me, but I am skeptical here. (IMG:style_emoticons/default/confused24.gif) Thanks! Mike in Munich Attached thumbnail(s) ![]() |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Too lean for WOT as it should be 11.5-12.5 to start at low rpms.
Timing should be set at 28 degrees @3500rpms so the Max advance in all in. Is the vacuum advance hooked up? (IMG:style_emoticons/default/confused24.gif) |
MikeInMunich |
Too lean for WOT as it should be 11.5-12.5 to start at low rpms. Timing should be set at 28 degrees @3500rpms so the Max advance in all in. Is the vacuum advance hooked up? (IMG:style_emoticons/default/confused24.gif) The vacuum advance is hooked up. The AFR is at 13.5. Timing is advanced 5 degrees. We will advance it to about 25, but believe the AFR can stay where it is. |
Lo-Fi Version | Time is now: 20th June 2024 - 06:03 AM |
