I'm down to first gear., UPDATED with tear down pictures. |
914bub |
Dec 11 2014, 07:12 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
After waiting 2 years to get my car to me,and another year sorting issues, replacing the clutch etc. I'm down to needing first gear. I have 2nd through 5th and reverse. I've read every thread I can find about shifter adjustment. Most pertain to side shifter transmissions but usually say that the process is similar, just different adjustment points for a tail shifter.
Can anybody tell me how to get 1st gear? Unlike other cars I've owned, it grinds when trying to get into first. The other cars I've owned might grind but you could "push past" the grind and jamb it into gear.It's almost like there isn't enough shifter throw to get it into 1st gear. I've replaced the ball cup bushing at the base of the shifter and have all the other bushings to replace the whole set. I've inspected the others and they don't seem wasted. I've tried putting it into first before starting the car and it's the same issue. Shifter doesn't have enough throw..... (IMG:style_emoticons/default/WTF.gif) Any help would be greatly appreciated. |
Dr Evil |
Jan 19 2015, 08:29 PM
Send me your transmission! Group: Members Posts: 23,031 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Both are shit. Sorry. The wear on the better one is still too much. Like trying to pick up a turd by the clean end.
The profile pic, while well done, is not useful as the teeth wear from the inside out so you dont see anything on the outside profile until it is all done. You should have one good set attached to one of your spare gears, no? |
Lo-Fi Version | Time is now: 25th September 2024 - 10:55 PM |
