rosenfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None ![]() |
my 73 2.0 started hesitating just this week when i rev at end of 1,2,3 gear,acts as though its not getting fuel,and it will just die if i come to an stop.i can get it started again,but it takes a bit of cranking. it will then run well and i have to keep revs up to avoid it dying at a stop .i changed fuel filters,have not changed tank sock.fuel pump is running.it has 2- 34 carbs, fairly new..
is this enough info to get some opinions.i wonder if either the fuel sock is full of crap or fuel pump is bad.it too is fairly new. |
rosenfe |
so im following up with my fuel starvation issue.after changing sock,filters i still had the problem.in fact now i was getting no fuel to pump at all.pump works,but i realized that plastic fuel hose to rubber taper hose from 9.5mm to 8 was old and getting crimped with the bend required to turn 90 degrees and connect to filter and pump.
i dont want to replace plastic to stainless steel at this time,but did notice that tangerine has a short curved ss line that is the same as rubber taper hose with 9.5 on one end to fit over plastic fuel hose and 8 on other end ot fit fuel hose to filter and pump. im trying to think of any alternative way to bush down without having to buy ss hose from tangerine.any ideas,its a tight fit with pump pressure regulator and filters. |
Lo-Fi Version | Time is now: 28th June 2024 - 01:09 PM |
