Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Thinking about drilling a 3/4 inch hole through the firewall to an Accusump on the other side. The Accusump will sit facing backwards towards the cockpit firewall mounted where the seat normally goes.
Anyone ever drilled through this section. There is a black arrow where I want the hole. All advice appreciated. ![]() BTW I'm going to cover up that higher hole where the lines used to run to the front cooler. |
Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
What Chris said. The center of that dimple matches a dimple on the interior of the vehicle. Any other spot on the lower firewall and you have to go through two pieces of metal spaced 2.5 or so inches apart. |
Randal |
(IMG:style_emoticons/default/agree.gif) What Chris said. The center of that dimple matches a dimple on the interior of the vehicle. Any other spot on the lower firewall and you have to go through two pieces of metal spaced 2.5 or so inches apart. Ahhh, now I see it. Just move the Accusump over to the right, drill a hole, install a bulkhead fitting and I'm good to go. So much easier and less costly than running the lines through the old hole. Man, the stuff we go through for better weight distribution! ![]() Thanks for the advice all! |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:44 PM |
