Mounting tips for QRS Fiberglass, Anybody work with them ? |
914GTSTI |
Jan 22 2015, 11:09 AM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Restarting my build and need some help with mounting the QRS Fiberglass GT fenders. Is their a BEST way ? Links to other builds ? Tried the search with limited success.
Thanks,Randy |
tadink |
Jan 22 2015, 09:01 PM
Member Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
I've also used the Dzus fasteners on mine - pix below - they are a pain to get lined up correctly. Be patient, go slow, figure out the depth of the 'plunger' mechanism that you need for the glass flares you've got.
I've got the fronts held on with rivets and adhesive - I think I prefer the Dzus overall. I tried to keep as much of the full panel as possible, but had to trim a bit since I was mounting over the existing tin vs. a direct replacement of the tin. The real 'pucker' happens when you begin to cut away the body - but be brave and go slowly!! I marked out the cuts with blue painting tape to guide me along the way. Since my goal was more 'race' and less 'show' I was not too concerned with the finished cosmetics....but all in all, I think I'd do it again with the f'glass panels.....the weight saved is significant!!! Next stage is to have the panels painted to match - and that is relatively less expensive to have the panels only professionally 'shot' vs having the whole car done. have fun! td |
Lo-Fi Version | Time is now: 24th June 2024 - 07:26 AM |
