BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,942 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
Ok, here goes. I picked up this '75 last April in lower Maryland. It was advertised as a 2.0, it has a 2.0 badge on the back, and it looked pretty good from a distance (or with beer goggles).
Attached thumbnail(s) ![]() |
saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
You are tackling some serious rust!
The suspension console is just a PITA to remove. For non-spot welds I ground down the welds a little at a time until I could get a big screwdriver in between to pry the metal apart. Spot weld cutting bits work great for the spot welds, but I never invested in a set that would hold up for a long time without getting dull. I used a set of Dewalt Cobalt bits for most of them. Keep up the good work! (IMG:style_emoticons/default/beerchug.gif) |
BeatNavy |
You are tackling some serious rust! The suspension console is just a PITA to remove. For non-spot welds I ground down the welds a little at a time until I could get a big screwdriver in between to pry the metal apart. Spot weld cutting bits work great for the spot welds, but I never invested in a set that would hold up for a long time without getting dull. I used a set of Dewalt Cobalt bits for most of them. Keep up the good work! (IMG:style_emoticons/default/beerchug.gif) Thanks, Bob! I'll try your technique. Didn't have too much time in the garage today, but I made some progress on the outer welds that are easily accessible: ![]() This thing IS going to be a PITA. Getting at those seams and the underside of the console will be a LOT of fun, especially with all that paint or undercoating. And those "brackets" (or whatever you call them) that hold the inner ear and outer console together -- not sure how exactly to remove them yet. Ground them down? Just cut them off? I also made a little "gauge" for helping me locate the outer console when I put it back on. I was just a little worried that the brace won't help me exactly locate the outer piece: ![]() |
Lo-Fi Version | Time is now: 18th December 2024 - 08:39 AM |
