Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,199 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
I think I have lost my mind.
I decided that I wanted to go with a more modern radio but did not want something that looked like it came from a disco. Unfortunately, most modern units fall into that latter category. First, I decided to go with a Nakamichi MBVI. The first one I ordered got lost in transit. The second one, from eBay, was supposed to be new but was used and defective. Got refunds on both and decided to give up on the Nakamichis. I also hear units of that time period were problematic. ![]() I then discovered a VDO unit that I think looks quite good and the VDO label sort of fits in. I ordered one from Germany and it should be here shortly. ![]() But wait, then I saw another Kienzle which is very feature rich yet subtle in appearance. Yup, also ordered one of them from Germany. ![]() Lastly, I then saw a Becker Traffic Pro BE4763 which was fitted to early Boxters. Not a great GPS but kind of neat to have and it says Porsche on it. That will be here soon also. ![]() Not sure which unit I will ultimately wind up using. The others will likely go up for sale here. Craziest part is that I mostly listen to the sound of the engine when driving the 914. Just thought I would share what I found for anyone considering a more modern unit without too much bling. |
monkeyboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None ![]() |
You do need to watch what radios you order. US radio bands are not the same as other countries. They do overlap somewhat but you can end up with a unit that will not work as a radio here.
I do know that Japanese radios do not work here. I was going to import one once. |
Amphicar770 |
You do need to watch what radios you order. US radio bands are not the same as other countries. They do overlap somewhat but you can end up with a unit that will not work as a radio here. I do know that Japanese radios do not work here. I was going to import one once. Yes, Japan operates FM at lower frequencies than most of the world. Analog radios from EU will also stop around 104 versus 107.9 for the USA. Many, not all, of the electronic units are designed so that you can select the region of the world in which you are using it. Much like CD's, terrestrial radio seems to be dying off. For a daily driver, you may want the full spectrum for your country. May be less important if you are going for a certain look and / or mostly use functions other than the Radio, I do have a Blaupunkt AM/FM/CB radio that I was thinking of using (actually have 2, one is NOS, the other does not seem to work on CB). Those stop at 104 on FM. The 24 CB channels all are the same as the US but there is no channel 19 which is the main frequency in the USA. You could switch out one of the crystals but they are soldered in place and it was a hassle I did not want to deal with. Still, it is a cool, mostly period correct unit with dual shafts. ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 07:03 AM |
