950 CC Type 4, 2 cylinder "big bore" |
Al Meredith |
Jan 29 2015, 04:32 PM
Senior Member Group: Members Posts: 967 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I've wanted to do this for years! I just finished a 2 cylinder Ty 4 engine. I had a case that was not in real good shape and a couple of 1.7 heaqds that were OK. I welded up the oil holes on #2 & 4 and welded up 4 cam folowers , had the 1.7 heads fly cut for a big bore (96MM) P & C and have 1/2 of a 1911. For now and for simplicity I installed a standard 32/36 setup. I installed it om my engine start up stand and it started right up and ran fine , 60 PSI oil pressure at idle. No need to send a picture because it looks just like a regular engine although it sounds like a motorcycle.
I have a question for the forum, any suggestions on a carb set up?? I have a couple of old 1.7 bus carbs with the manifolds , I can use one of these carbs and center mount it . I can just continue to use the 32 MM weber and block off the 36 MM side??? any help. AL |
Mueller |
Jan 30 2015, 09:36 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I guess you could also convert it into a portable gas powered air compressor!
Mark Henry |
Jan 30 2015, 10:45 AM
I guess you could also convert it into a portable gas powered air compressor! But wouldn't you keep the extra 2 cylinders (IMG:style_emoticons/default/confused24.gif) There used to be a type one kit to do this: http://www.thesamba.com/vw/forum/viewtopic...098&start=0 |
Lo-Fi Version | Time is now: 26th September 2024 - 05:32 PM |
