Improving exhaust sound, Best aftermarket muffler? |
Last930 |
Jan 31 2015, 11:14 AM
Member Group: Members Posts: 60 Joined: 15-September 14 From: Illinois Member No.: 17,905 Region Association: Upper MidWest |
My '73 2.0 sounds like a, well, Volkswagen. How do I go about making it sound better? It is a stock engine with FI intact. The existing muffler seems to have a couple small leaks. I would like to retain the heat as well as use the single outlet setup. The power train is coming out this spring so I can paint the engine compartment, so that's would be a good time to tackle the exhaust.
Any suggestions to make the car sound like a sports car would be appreciated. |
Tom_T |
Jan 31 2015, 11:39 AM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
If you want to keep the single outlet, then you're pretty much limited to either a new - non-leaking - OEM style banana muffler from Dansk available at Porsche dealers & other Porsche suppliers; or a custom from Tangerine or some others.
You might also luck out to find an older NOS or good condition used factory/OEM sport version of the banana 1-outlet muffler, which had a throatier sound & a bit better flow, due to less baffling. Not having a swiss cheese stock muffler will make it sound quite a bit better, but still like the original street T-IV 914 2L sound. The hole allow too much leakage, so you're basically probably only getting a loud "pfffft!" right now! (IMG:style_emoticons/default/biggrin.gif) If you can go to more than 1 outlet, then that opens up customization of the banana to dual outlets, Bursch mufflers, Trident, etc. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
ChrisFoley |
Jan 31 2015, 11:52 AM
I am Tangerine Racing Group: Members Posts: 7,967 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
... or a custom from Tangerine ... We now have an off the shelf product for the 2L heat exchangers. Tangerine EVO IV |
Lo-Fi Version | Time is now: 22nd December 2024 - 11:29 AM |
