> New Suby build on my old v8 car- Change of plans, Selling this car to a buddy. The WRX motor will be going in my green 914
JRust
post Jan 10 2015, 02:39 PM
I've put this car off long enough. I am buying a 2004 WRX motor to put in. As well as a suby tranny. I plan to get everything up & driving in this car. Then swap the drivetrains with my green car. We'll see how that plays out.
I need to replace the firewall section that was cut out by the PO in the late 80's. I'm going to replace the lower cutout of the firewall first. I like the idea of making the upper section of the firewall removable. Nice to have access from the front if possible. At least while I am getting it all setup. If I don't feel the need later I'll just make the firewall stock.
I've got the 911 rear axles already so will need to get those resplined for the suby CV tranny side. I've got the suby tranny I'm buying from Bob. I plan to do my motor cradle mount a little different. Not really planning on a cradle. I'll draw something up on it & post it later. Basically will use the engine bar mounts. But I plan to have an bar arch to the firewall where there will be another mount but a sideways tube. So there would be three mount points on the bar. the typical spots for the engine bar. Plus the front mount which will pivot. So when bolting in the drivetrain. You would get the front of the motor up first. Then lift the tranny up & bolt in place. Then the engine bar mounts. This will keep everything nice & out of the way for the exhaust. I came up with this thinking of the Porsche 6 firewall mounts. Anyway it will make more sense with a picture.
For the WRX motor. It has the Stock ECU with wiring setup for a 914 with the ECU flashed. Not sure if I'll be keeping that setup or using my spare Stinger ECU. Motor has a round 55k on it. I plan to do the timing chain & head gaskets while it's out. I'm also looking into getting bigger injectors, Fuel Rail & bigger turbo. I may wait on that but getting all my options of upgrades before it goes in. My plan is for this motor to go in my green car eventually. I'm going to get it all up & running in my old v8 car. Then make the decision to swap it. Then my old car will get sold.
Well there is the start of the plan. I'll update as things come in
mgp4591
post Feb 1 2015, 06:06 PM
It's always tough to let a loved one go... (IMG:style_emoticons/default/sad.gif)
JRust   New Suby build on my old v8 car- Change of plans   Jan 10 2015, 02:39 PM
relentless   Looks like a nice ambitious project Jamie. But da...   Jan 10 2015, 03:01 PM
JRust   Looks like a nice ambitious project Jamie. But d...   Jan 10 2015, 03:22 PM
Mike Bellis   Put all the STI bits on it and you'll be close...   Jan 10 2015, 09:30 PM
Hank914   That looks like a great project. One of these day...   Jan 10 2015, 10:27 PM
JRust   Okay so my drawing here is really crude. This is j...   Jan 10 2015, 10:41 PM
rnellums   I'm thinking of doing something similar to mak...   Jan 11 2015, 05:30 AM
DBCooper   I think you may have a problem routing that exhaus...   Jan 11 2015, 07:04 AM
BIGKAT_83   Jamie I think instead of reinventing the wheel I t...   Jan 11 2015, 10:19 AM
JRust   I am getting the engine complete with exhaust. Whi...   Jan 11 2015, 10:44 AM
DBCooper   My turbo's in the stock location and we did ha...   Jan 11 2015, 12:05 PM
PanelBilly   Not trying to be critical here, but have you thoug...   Jan 11 2015, 12:20 PM
DBCooper   Not trying to be critical here, but have you thou...   Jan 11 2015, 01:00 PM
Mueller   Not trying to be critical here, but have you thou...   Jan 11 2015, 01:59 PM
JRust   Not trying to be critical here, but have you thou...   Jan 11 2015, 03:19 PM
mepstein   Even porsche made 2 factory 914-8's. I think p...   Jan 11 2015, 03:11 PM
JRust   The v8 was ditched long ago. Car has been a roller...   Jan 11 2015, 03:15 PM
JRust   Well plans have changed. Had a friend here I was c...   Feb 1 2015, 06:02 PM
mgp4591   It's always tough to let a loved one go... :(   Feb 1 2015, 06:06 PM
- Lo-Fi Version Time is now: 6th January 2025 - 08:56 PM
