> My 914-6 Oil Cooler Install
patssle
post Feb 14 2015, 06:58 PM
I attempted my 914-6 conversion with a 3.0L without running an external oil cooler. Some have said they have done it so I figured if I could save a grand of dollars that would be nice. But my extended freeway driving took it to around 240 and I didn't push it any further. So thus I caved and installed an external oil cooler.
Engine oil ouput line
Existing Remote Filter Mounted in Trunk
Mocal 25 Row, 235 Matrix Mounted
Braced Against Muffler Bracket
Fan Mounted
Electrical - Grounded to Transmission Ground
Relay Mounted - Main Power off Bus Bar, Ignition from Relay Board
Mocal Remote Oil Thermostat
Putting It Together
Finished!
Brings temps down to 190 @ idle
patssle
post Feb 14 2015, 08:28 PM
I don't have an oil filter on my tank - my aftermarket /6 tank was poorly built and the filter console was off-center drilled. So I mounted an -12 AN fitting into the filter console and that's where the oil filter outlet feeds to!
Also with this design it was modular - I was able to add the oil cooler with no additional costs of re-routing lines or changing fittings. See the black coupler in the 2nd photo.
patssle   My 914-6 Oil Cooler Install   Feb 14 2015, 06:58 PM
brant   Weight in the rear trunk is not ideal   Feb 14 2015, 07:03 PM
Steve   My 914 trans cooler was in the same spot and worke...   Feb 14 2015, 08:00 PM
patssle   I don't have an oil filter on my tank - my aft...   Feb 14 2015, 08:28 PM
siverson   Thanks for sharing. But I don't understand yo...   Feb 14 2015, 10:23 PM
patssle   Thanks for sharing. But I don't understand y...   Feb 14 2015, 11:14 PM
Steve   Here's how Otto's did my trans cooler.   Feb 14 2015, 10:53 PM
McMark   Did you try replacing the stock on-board thermosta...   Feb 15 2015, 04:25 PM
patssle   Yes I tested the thermostat before I put the /6 en...   Feb 15 2015, 08:35 PM
worn   Yes I tested the thermostat before I put the /6 e...   Feb 15 2015, 09:44 PM
Mark Henry   Yes I tested the thermostat before I put the /6 e...   Feb 16 2015, 10:42 AM
worn   Tour de force! Thank much as I am mulling over...   Feb 15 2015, 09:37 PM
pcar916   An aluminum cooler has almost no structural integr...   Feb 16 2015, 11:17 AM
Steve   Even though my trans cooler is mounted to the body...   Feb 16 2015, 11:25 AM
patssle   Still looking into vibration solutions but I reloc...   Feb 22 2015, 12:31 PM
thieuster   Still looking into vibration solutions but I relo...   Feb 22 2015, 12:37 PM
Dave_Darling   N.B.--that's one of the rear sway bar mounts, ...   Feb 22 2015, 09:08 PM
patssle   Maybe in a previous life...it's an oil cooler ...   Feb 22 2015, 09:51 PM
- Lo-Fi Version Time is now: 5th February 2025 - 03:45 AM
