lmcchesney |
Member ![]() ![]() Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None ![]() |
I put the engine back in and cranked it over following the rebuild. I found significant oil leaking/draining from behind the impeller housing. I ended up pulling the enginen out and looked at the source, thinking I did not get the oil in and out barbed fittings tight. To my suprise, I found a fitting hole which I cannot remember what its purpose is. I believe this to be the source of oil loss.
This is a modified 2.0L. We run an external oil cooler in series with our stock oil cooler. Denny removed the stock oil filter mount and capped it off with a plate. He plumbed the case for _8 fittings for oil in and out to the external oil cooler and remote mounted oil filter. Attached image(s) ![]() |
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
QUOTE(groot @ Aug 31 2004, 12:45 PM) dr, are you on the track yet? I ran a race (test session for me) at Waterford Hills this weekend. Learned a lot. Trying to get the motor set-up. Hard to find time during the week. dr |
Lo-Fi Version | Time is now: 26th June 2024 - 08:58 AM |
