> Bursch Header / Muffler, Bursch Header / Muffler revision to mitigate rasp
forrestkhaag
post Feb 16 2015, 10:14 AM
I am interested in a solution for creating a decent muffler by using my recently purchased Bursch Header/Muffler setup to best feature the new and improved sounds that will emanate from the rear of my (newly built) 2.2L 914.
Recently, I purchased a new-in-box Bursch system that was supposed to be Street Quiet.... - but it isn't close to "street quiet" even on my 1.7 engine as it is presently in the car. My approach is lop off the muffler-can on the Bursch product, then splice in a Magnaflow or other real live tuned muffler-element, then add the outlet pipe to match my valance contours. Size matters. The add-on needs to clear the underside heat shield as I do not want to cook my lovely wife's unmentionables while touring the California Coast.....
: Sidebar: My pal on 914W Larmo has the Bursch system on his 1.7 and it has a totally different and very decent sound as installed / right out of the box / - and it was purchased in Pasadena from the same supplier / maybe my system did not have the "street-Quiet" can welded to it but his is clearly different and decently throaty but not raspy in sound - both on 1.7 stock FI engines..... not sure what gives..
Do any out there have a recommendation for a replacment insert-piece (Magnaflow, or other) to gain a decent amount of muffling while featuring a throaty tune that will respect the neighborhood while mildly inflating the ego of the driver (me) while at the same time, eliminate the sneers, recoil, and window-slams of the neighbors............
Thanks for your assistance
forrestkhaag
post Feb 21 2015, 10:09 AM
The welding was the easy part. On my 71, I have the snow-shovel rear valence so I wanted to line up the tail pipe precisely with the existing valence-hole. I sliced off 1.75 inches of the exit-side of the pipe then mated the muffler with the Bursch header(?) assembly then inserted the Bursh tail pipe / then mounted the whole assembly to align all three pieces. The fit is good and tight so I was able to tap each piece into alignment, then bring up the valence to confirm the hole-shot, then remove the muffler and pipe assembly as one unit, put it on my work bench and weld it up. I used my Lincoln wire-feed (no gas required) and found that the muffler metal was softer than the Bursh pieces. Continuous welds around the two pipe connections were completed. The an adjustment to the supporting tab on the tail pipe was made for its new relationship to the MagnaFlow muffler was welded into place.
I bolted it up to the car, fired it up and two of my neighbors popped out of their bunkers, brought over bottles of wine, and listened to the music.
- Lo-Fi Version Time is now: 5th January 2025 - 12:59 AM
