914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Okay this is the car in all its glory ugly as heck, but hey its an auto-x car. (IMG:style_emoticons/default/new_shocked.gif) This one is from my first season of auto-x with this car.
![]() Heres what it looks like today. Made it even uglier (IMG:style_emoticons/default/barf.gif) ![]() Here is the goal, I can sketch ideas, but I can not draw at the level of others on this forum. Thank you 914 Visulizer. and my black pen. Now if I could find a good front view. And the flares are not on the car since I'm not using GT Flares. ![]() But you get the general idea. |
914forme |
spent the day finishing stripping the car. Doors off, had to cut my parking brake handle pin that holds the cable out, as it was stuck. vacuumed everything up, and started cutting un-need brakes and studs out of the body shell. Lots of drilling of spot welds. And I only drilled all the way through one spot weld. Ventilated my floor board under the passenger seat. (IMG:style_emoticons/default/headbang.gif)
![]() Nothing a (IMG:style_emoticons/default/welder.gif) can't fix. ![]() ![]() Also started working on the Alternator mount for the EG33, going to put it where the Power Steering pump was. And try and use the belt adjuster from the Power Steering bracket. No pictures of that yet After I removed the doors, I found this damage left over from a fender bender. ![]() I'll need to take measurements and make sure Im good. |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:30 AM |
