Need help with Vellios 916 shifter parts |
Marv's3.6six |
Feb 18 2015, 04:12 PM
Actual member 7" Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California |
Hey all I need help with Vellios shifter.
I am looking for a drawing of the shift fingers. I need to replicate or repair mine. Does anyone have a drawing of this part? (I am speaking of the shifting levers or fingers, not the cast aluminum part) Thanks Marv Attached image(s) |
Marv's3.6six |
Feb 21 2015, 03:06 PM
Elliot Cannon-Did you break that car already?
No E, it has never shifted right since the rebuild. Somehow Don from Precision Motion severally bent the the tunnel shift rod. The shift rod was bent into a banana and was left that way, then he went about grinding various other parts to try fix the problem to make it shift. The shift fingers have had a lot of the material removed. And of course none of the Vellios parts are available anywhere. |
Elliot Cannon |
Feb 21 2015, 09:45 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Elliot Cannon-Did you break that car already? No E, it has never shifted right since the rebuild. Somehow Don from Precision Motion severally bent the the tunnel shift rod. The shift rod was bent into a banana and was left that way, then he went about grinding various other parts to try fix the problem to make it shift. The shift fingers have had a lot of the material removed. And of course none of the Vellios parts are available anywhere. Bummer. You want I should call Vinnie and Guido? (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 30th June 2024 - 08:23 PM |
