> Factory 2.0 L Exhaust Nut vs Copper Nut, A Compairson of the Two
914Sixer
post Feb 26 2015, 10:12 PM
This might explain difference in cost between the two. The 2.0 nut is used and the copper is new. Note the copper one has elongated hole.
Cap'n Krusty
post Feb 27 2015, 12:23 PM
Cap'n Krusty
Again, you're joining the ranks of those who call those things "copper" nuts. They're NOT copper, they're STEEL, with a copper plating. Clearing out the "pinch" makes them regular nuts with a hefty price tag.
The Cap'n
JamesM
post Feb 27 2015, 12:58 PM
QUOTE(Cap'n Krusty @ Feb 27 2015, 11:23 AM) *
The Cap'n
Force of habit as that is how they are advertised EVERYWHERE.
Personally if I can't find OEM ones I will go with these:
http://vwparts.aircooled.net/ACN-Flanged-R...-p/acn-nuts.htm
REALLY nice when dealing with larger OD header stubs.
pete000
post Feb 27 2015, 06:51 PM
QUOTE(JamesM @ Feb 27 2015, 10:58 AM) *
The Cap'n
These are the ones I went with. They worked fine with my SSi's and were no trouble to install.
914Sixer   Factory 2.0 L Exhaust Nut vs Copper Nut   Feb 26 2015, 10:12 PM
GeorgeRud   I believe the elongated center in the copper nut i...   Feb 26 2015, 10:20 PM
McMark   Yup, the top threads are squished. It's the w...   Feb 27 2015, 10:22 AM
Dave_Darling   Sixer, can you look at the OEM nut to see if there...   Feb 27 2015, 10:59 AM
Cap'n Krusty   I have one sitting right here. No slice, no defor...   Feb 27 2015, 11:10 AM
JamesM   The copper nuts are awesome at pulling exhaust stu...   Feb 27 2015, 12:05 PM
Al Meredith   I like the copper nuts BUT I run a 8X125 tap throu...   Feb 27 2015, 12:13 PM
Cap'n Krusty   Again, you're joining the ranks of those who c...   Feb 27 2015, 12:23 PM
JamesM   Again, you're joining the ranks of those who ...   Feb 27 2015, 12:58 PM
pete000   Again, you're joining the ranks of those who...   Feb 27 2015, 06:51 PM
rjames   Okay, so what's the proper replacement for the...   Feb 27 2015, 12:46 PM
Al Meredith   Correct ! I like them because they don't s...   Feb 27 2015, 12:46 PM
914Sixer   James, you may find the nuts your are looking at a...   Feb 27 2015, 04:27 PM
JamesM   James, you may find the nuts your are looking at ...   Feb 28 2015, 11:45 PM
Woody   Again, you're joining the ranks of those who ...   Feb 27 2015, 04:50 PM
plays with cars   Sixer, can you look at the OEM nut to see if ther...   Feb 28 2015, 08:45 PM
patssle   I went through this myself last year when completi...   Feb 28 2015, 08:57 PM
aircooledtechguy   As the Cap'n mentioned, OEM nuts were steel wi...   Mar 3 2015, 09:24 AM
rdauenhauer   Or if your a hoarder :) your already sitting on a ...   Mar 3 2015, 09:39 AM
Phoenix914   Is it appropriate to use something like this on th...   Mar 3 2015, 09:51 AM
Steve Pratel   From what I understand, Copper antiseize is the be...   Mar 3 2015, 11:16 AM
Phoenix914   The Loctite product is rated 200 deg higher than t...   Mar 3 2015, 11:29 AM
Cap'n Krusty   Hmmmmm, if I'm not mistaken, Loctite and Perma...   Mar 3 2015, 01:08 PM
'73-914kid   Hmmmmm, if I'm not mistaken, Loctite and Perm...   Mar 3 2015, 04:33 PM
Mike D.   I found these when I was installing the 914 motor ...   Mar 3 2015, 11:03 PM
ThePaintedMan   I wonder if this is something we could put in a re...   Mar 4 2015, 07:54 AM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 08:47 PM
