stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I bought these tie downs:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1425160022.1.png) But the stock bolts seem to be a little short to stick the tie down between the shock & trailing arm while retaining the thick washer under the stock bolt head. The stock bolt is 18mm X 1.5 X 130mm. The tie down is 5mm. Bolts that large typically come in 10mm increments, so I would need 18mm X 1.5 X 140mm. I have found them but for $25 ea plus shipping. Anyone have a source for the bolts cheaper or a trick to installing these with the stock bolts? Are the bolts that have the attachment points for the rear swaybars just a tiny bit longer? |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
You would be creating more of a lever to possibly bend the bolt. Personally I'd keep it where you have it, and get a longer bolt. I may be able to get you better pricing. I'll check in the morning, sounds like its possible. What is the grade?
Lo-Fi Version | Time is now: 26th June 2024 - 03:59 AM |
