Volt Meter Reading Analysis Needed |
Ansbacher |
Mar 9 2015, 06:54 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Simple question, I think. With engine running and no extra electrical loads turned on, my voltmeter reads a bit over 13 Volts. Turn on headlights and voltage drops to a bit above 12 Volts. Is that a normal drop or is something going on with the voltage regulator or alternator?
Ansbacher |
Dave_Darling |
Mar 10 2015, 12:55 AM
914 Idiot Group: Members Posts: 14,994 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The center console voltmeter is mostly there for "entertainment purposes". After you get used to how it works in your particular car, you can also use it as a quick check for if your lights are working. If the voltage drops by less than you expect it to, you may have a burned-out bulb...
--DD |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:20 PM |
