> Porscheru Engine Choices, 2.2, 2.5, or 3.0 ??
R_u_dd
post Mar 9 2015, 10:45 PM
Added a poll Here
Building a Porsche 914 with Subaru power and transmission Porscheru. Looking for a donor car with a 5mt transmission. I've considered many engine combos. The 2.0 wrx turbo is very popular for this build at 227 hp but I want NA power without the turbo lag. I've narrowed it down to these combos:
EJ22 99-2001 142 horsepower. Less power than I would like, but easy to find a car with a stick shift and fewer head gasket problems. Good potential for additional power. Strong motor.
SOHC 2.5 1990-2004 165 HP. This is a good power range for the lightweight 914 (2,400lbs). Easy electronics. The negative is frequent HG problems. The donor car is hard to find with a stick shift. If I buy a donor car with an automatic tranny, which 5mt will fit, just match the year?
EZ30D 2000-2003 212 HP. The donor car will need a tranny. Which should I buy?
So the big question is which donor would you buy and why? I don't want to buy individual parts if I can avoid it because it's much more expensive and the combinations might not work well together. Individual parts are about $2,000 but I think I can get a donor for around $1500.
DBCooper
post Mar 10 2015, 09:18 AM
14's in the 13's with ATTITUDE
The Canbus electrics have made it impossible to use the later Subaru motors (2009 and newer, if I recall correctly) with the OEM ECU's. With Canbus you can't just peel out the whole wiring harness out and strip out unneeded sensors, you need it all, intact, with the fuel level sensors, auto trans info, etc. etc. So if it's Canbus it's been that you need an aftermarket ECU, using the OEM isn't really viable. Except that I just noticed on the Subarugears site they have a box that fakes all those other Canbus signals, so you can use the Subaru ECU. I could never sort out that mess of wiring, so for me an aftermarket ECU makes sense, but if you're after a nearly new engine and want to use the OEM ECU that box might make it viable. I don't know details, cost or anything, just noticed it.
Also, by the way, you DON'T have to have an ECU that controls the later AVCS valve system. An alternative is to install non-ACVS cams, meaning you can go hot-rod cams at the same time if you like. It's a slightly dumber engine without AVCS, but same peak torque and HP. So there's no particular need to stick with the older engine models, whether OEM or aftermarket ECU.
R_u_dd   Porscheru Engine Choices   Mar 9 2015, 10:45 PM
rnellums   I went the EZ30D route. I bought parts piecemeal,...   Mar 9 2015, 11:16 PM
R_u_dd   Great info. Ian has info on the 30R and it sounds...   Mar 9 2015, 11:33 PM
rnellums   Great info. Ian has info on the 30R and it sound...   Mar 9 2015, 11:41 PM
gryphon68   I would get the longest geared transmission you c...   Mar 10 2015, 05:47 AM
Scarlet75   Posted this in the Nasioc forum: Building a Pors...   Mar 10 2015, 07:33 AM
brant   Posted this in the Nasioc forum: Building a Por...   Mar 10 2015, 07:38 AM
76-914   [quote name='Scarlet75' post='2157661' date='Mar ...   Mar 10 2015, 08:35 AM
R_u_dd   What auction site? The auction site I use ...   Mar 10 2015, 08:36 AM
Scarlet75   [quote name='Scarlet75' post='2157661' date='Mar ...   Mar 10 2015, 08:47 AM
R_u_dd   Ok this is what I did. I found an auto auction on ...   Mar 10 2015, 08:31 AM
Chris H.   BIGKAT_83 has an EZ30R engine he was thinking abou...   Mar 10 2015, 07:51 AM
gryphon68   BIGKAT_83 has an EZ30R engine he was thinking abo...   Mar 10 2015, 03:49 PM
DBCooper   The Canbus electrics have made it impossible to us...   Mar 10 2015, 09:18 AM
OU8AVW   I'm planning a Suby conversion on my '89 W...   Mar 10 2015, 10:31 AM
Scarlet75   I chose the self repair option. I am in no rush to...   Mar 10 2015, 11:22 AM
mepstein   I bought a running SVX for $500. For $10...   Mar 10 2015, 11:23 AM
76-914   The EZ30 is only 1.5" longer than the 2.5L 4 ...   Mar 10 2015, 03:14 PM
R_u_dd   The EZ30 is only 1.5" longer than the 2.5L 4...   Mar 10 2015, 07:04 PM
rnellums   The EZ30 is only 1.5" longer than the 2.5L ...   Mar 10 2015, 07:48 PM
partwerks   The EZ30 is only 1.5" longer than the 2.5L 4...   Aug 7 2022, 07:51 PM
porschetub   The EZ30 is only 1.5" longer than the 2.5L ...   Aug 7 2022, 10:39 PM
76-914   The EZ30 is only 1.5" longer than the 2.5L ...   Aug 8 2022, 09:52 AM
effutuo101   2004 2.5L NA motor would be an easy fix and instal...   Mar 10 2015, 03:44 PM
Chris H.   Right, the engine in his car is an EZ30D (the car ...   Mar 10 2015, 03:58 PM
Chris H.   It's very easy to use a manual trans with an E...   Mar 10 2015, 07:51 PM
- Lo-Fi Version Time is now: 28th December 2024 - 12:31 AM
