Type IV plenum intake manifold questions..., Why single and not double like the 911 motor? |
Mueller |
Mar 14 2015, 10:28 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Has anyone made a dual plenum like used on the 911 engines for a Type IV?
r_towle |
Mar 14 2015, 05:04 PM
Custom Member Group: Members Posts: 24,645 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I recall seeing a race car running two full Djet setups with two plenum a and two throttle bodies etc, the plenums are welded together
Mark Henry |
Mar 14 2015, 05:11 PM
I recall seeing a race car running two full Djet setups with two plenum a and two throttle bodies etc, the plenums are welded together Maybe oldschool with D-jets, but why would you do this with modern programmable FI? The only reason to do this over ITB's is for a more stable MAP sensor signal with the single TB intake. It's why Porsche did it. |
r_towle |
Mar 15 2015, 12:57 PM
I recall seeing a race car running two full Djet setups with two plenum a and two throttle bodies etc, the plenums are welded together Maybe oldschool with D-jets, but why would you do this with modern programmable FI? The only reason to do this over ITB's is for a more stable MAP sensor signal with the single TB intake. It's why Porsche did it. The one I saw, I think DD know about it, but it was a long time ago, and posted here, was two full DJet setups to make a larger motor work. Personally I think it was a cool thing to try, but doing it today I would just go with a single larger throttle body, and modern EFI |
Lo-Fi Version | Time is now: 28th November 2024 - 04:35 PM |
