> Type IV plenum intake manifold questions..., Why single and not double like the 911 motor?
Mueller
post Mar 14 2015, 10:28 AM
914 Freak!
Has anyone made a dual plenum like used on the 911 engines for a Type IV?
r_towle
post Mar 15 2015, 01:04 PM
Custom Member
A bit confused on the pictures Mike.
My 911 (3.2 stock) uses one large throttle plate with the dual plenum shape, but it does not use individual throttle plates for each cylinder, and not sure what that might buy you honestly.
In my opinion, there are enough other parameters to deal with that adding in individual cylinder tuning just makes it harder....
I think there is a better way to make the motor deliver everything it can, and that would be good head design, proper valve train setup and lots of testing to make sure all cylinders are performing at the same level.
Tuning to match might creat some bad stress on the crank and make the motor run poorly due to mis matched power from each cylinder. I would rather sacrifice some power and tune down to the weakest cylinder instead of maxing out each cylinder, just seems like a bad recipe for longevity.
Rich
toon1
post Mar 15 2015, 02:43 PM
QUOTE(r_towle @ Mar 15 2015, 12:04 PM) *
Rich
The last part of your statement is confusing.
What your describing(the way I'm understanding it) is blue printing, which is a good .
How would improving intake air flow un balance the cylinders and be hard on the crank?
Mueller   Type IV plenum intake manifold questions...   Mar 14 2015, 10:28 AM
Bob L.   Someone here has played around with it. I forget w...   Mar 14 2015, 10:44 AM
Mike Bellis   Maybe it's because the 911 unit is engineered ...   Mar 14 2015, 11:03 AM
Mark Henry   I played with the design, it would work but only a...   Mar 14 2015, 05:01 PM
r_towle   I recall seeing a race car running two full Djet s...   Mar 14 2015, 05:04 PM
Mark Henry   I recall seeing a race car running two full Djet ...   Mar 14 2015, 05:11 PM
r_towle   I recall seeing a race car running two full Djet...   Mar 15 2015, 12:57 PM
Mark Henry   Here.... I'll save you a shitload of research ...   Mar 14 2015, 05:22 PM
type47   Tangerine Racing system as seen at Hershey   Mar 14 2015, 09:20 PM
Jake Raby   When I've gone this way the result was an even...   Mar 14 2015, 10:28 PM
Mark Henry   When I've gone this way the result was an eve...   Mar 15 2015, 07:05 AM
toon1   When I've gone this way the result was an eve...   Mar 15 2015, 09:24 AM
toon1   Mike, look up Hemholtz resinator and supercar int...   Mar 14 2015, 10:28 PM
Mueller   If you notice on the 911 engine, they are using in...   Mar 15 2015, 09:41 AM
toon1   There is some cool stuff out there. I just seen a ...   Mar 15 2015, 09:45 AM
Mueller   There is some cool stuff out there. I just seen a...   Mar 15 2015, 11:33 AM
r_towle   A bit confused on the pictures Mike. My 911 (3.2 ...   Mar 15 2015, 01:04 PM
toon1   A bit confused on the pictures Mike. My 911 (3.2...   Mar 15 2015, 02:43 PM
McMark   I suspect the 911 intake developed two 'plenum...   Mar 15 2015, 05:26 PM
toon1   I suspect the 911 intake developed two 'plenu...   Mar 15 2015, 05:55 PM
r_towle   [quote name='McMark' post='2160471' date='Mar 15 ...   Mar 15 2015, 08:35 PM
McMark   To what end? Why spend the time engineering? And...   Mar 15 2015, 06:39 PM
larss   Not that it adds wery much but this is my expetime...   Mar 16 2015, 02:18 AM
19 User(s) are reading this topic (19 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th November 2024 - 04:54 PM
