Yet another blake bleeding question |
florida 914 |
Mar 21 2015, 09:17 PM
Newbie Group: Members Posts: 29 Joined: 29-September 10 From: Salem, OR Member No.: 12,227 Region Association: Pacific Northwest |
Sorry, folks, for asking yet another question about bleeding brakes, but I can't find the answer to this specific question and am at wits end.
I have a 1971 914. I am only able to get about a quarter of a pedal, i.e. it is off the floor, but only just, and no more improvement no matter how much we go through the routine. What seems weird is this: when I open the rear bleed nipples, the pedal goes to the floor (as my assistant pushes), but nothing like that happens on the front. I don't see air being pushed through on any corner any more, but there is fluid moving on all four corners (though probably more on the back than the front). And the pedal never pumps up better than a quarter or so even with all nipples closed. We have installed rebuilt calipers, new pads, new flex lines, and a new master cylinder (in fact, we tried a second new master cylinder on the theory that the first may have been faulty). As far as I can tell there is no clog in the fixed lines (we checked the front especially). Any suggestions? Thanks! |
screenguy914 |
Mar 22 2015, 01:21 AM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Don't understand the need to confirm the existence of a return spring. If the pedal doesn't retract on its own, there's an issue. If it does, look elsewhere. Since it's a new MC, there's a chance it's faulty. If it was the existing MC, I would suspect a cup was torn when the pedal went to the floor during the manual bleeding procedure.
Confirm the MC is creating pressure at the front and rear outlet ports. Simply remove the appropriate MC brake line and depress the pedal with a finger (or equivalent) blocking the port. Don't get brake fluid in your eyes. Sherwood |
Lo-Fi Version | Time is now: 18th June 2024 - 06:20 AM |
