More shift linkage R&D at Tangerine Racing, Precision adjusters for all! Tailshift 4 & 6 prototypes shown |
ChrisFoley |
Mar 10 2015, 09:18 AM
I am Tangerine Racing Group: Members Posts: 7,976 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I'm expanding the application of my newest design to include all tailshift and 915 transmissions.
A precision adjuster will be available soon for these 914 applications: 914-4 tailshift 914-6 tailshift WEVO 915 Vellios 915 916 trans. This is what the adjuster unit for a 915 setup looks like. The rear connection will need to be different for 901 tailshift applications. |
Steve |
Mar 26 2015, 05:32 PM
914 Guru Group: Members Posts: 5,797 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
How about one for the Martin Bott 916 trans? I am using a PMS shifter rod and firewall bearing and still need the piece from the firewall to the trans.
ChrisFoley |
Mar 27 2015, 06:25 AM
How about one for the Martin Bott 916 trans? I am using a PMS shifter rod and firewall bearing and still need the piece from the firewall to the trans. The first one shown is for all 915 versions. I can make the rod diameter for a standard bushing or a PMS firewall bearing. The PMS shifter rod has a major shortcoming - the front cone screw hole is a straight bore, not a tapered bore. That rod would need modification to be used with the precision adjuster anyway so... My recommended setup uses either a sideshift rod turned around or a tailshift rod shortened a couple inches. I can make the rod under the engine, but I would need a measurement to determine the correct length. |
ChrisFoley |
Mar 27 2015, 06:29 AM
duplicate post
Lo-Fi Version | Time is now: 5th February 2025 - 01:52 PM |
