D-Jet Problems, Stalls when hot, misses at med. rpms |
john_g |
Mar 27 2015, 09:28 PM
Member Group: Members Posts: 110 Joined: 1-November 12 From: british columbia Member No.: 15,100 Region Association: Canada |
I'm having problems that I'm pretty sure come from somewhere in the D-jet system. I have a '74 914, bored to 2056. Here are my symptoms:
It idles okay. It's a bit rough when cold, but it doesn't cut out on me and warms up to a steady idle quickly (1200 when cool, 800-900 when warm), but when it's been run for a longer time and is good and hot, the idle drops well below 800 and it stalls. It'll start back up right away but only if I treat it as if it's flooded - I have to put the accelerator to the floor as I restart it. Secondly, at mid rpm's, between 2200 and 2800, it hesitates, sputters, misses, and occasionally backfires - this happens whether it's cold or warm. What I've done or have had done: usual tuning routine replaced the CHT sensor replaced the MPS replaced the distributor cleaned the PVC valve checked for vacuum leaks checked the TPS, it seems good Two air-cooled mechanics with good reputations have worked on it and haven't been able to solve the problem fully. All the above helped a bit, but the situation is still there. There has to be some sensor that isn't reading the situation correctly. Any ideas, or ... has anyone had a similar problem? (IMG:style_emoticons/default/confused24.gif) |
TheCabinetmaker |
Mar 28 2015, 06:43 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The plot thickens. Non stock cam changes everything. Have you retuned the mps?
john_g |
Mar 29 2015, 12:30 PM
Lo-Fi Version | Time is now: 22nd June 2024 - 07:37 PM |
