> Porsche 914 Starter/Wiring/Vacuum Hose Questions, Wiring and Vacuum Hose Questions
91422.7
post Mar 29 2015, 09:12 PM
Having problems getting the starter to engage! I have a 1970 Porsche 914 which I've just installed a 1975 914 2.0L F.I. engine. I've attached a photo of the starter hookup. It appears from the starter solenoid there is a blue wire or red/black wire that suppose to go to the ignition switch! Does that wire actually go to the Fuse Relay Block Panel first then on to the ignition switch? Question #2: from the picture you can see the Air Aux Regulator which has 2 outlets, one comes from the air breather, where does the other one go? Question #3: One of the injectors slides in and out pretty easy, the other 3 don't, is that because the one has a faulty inner rubber seal? Question #4: Is there a problem using the 1970 Fuse Relay Block (Engine Compartment) since I'm using a later model (1975) 2.0L F.I. engine or do I need to upgrade to a FRB out of a 1975 914? Thanks again for all your help!
JeffBowlsby
post Mar 29 2015, 10:27 PM
914 Wiring Harnesses
Two issues I see:
That big yellow wire on the igniotin harness that is just hanging, must attach to the starter.
See here for the vacuum hose layout for the AAR: http://bowlsby.net/914/Classic/TechNotebook.htm
That ignition harness you have is not correct for a 75 2.0L, it is an Ljet harness. Will not work with a standard 2.0L setup.
The relay board is compatible with all 914/4 cars.
91422.7   Porsche 914 Starter/Wiring/Vacuum Hose Questions   Mar 29 2015, 09:12 PM
Jeff Bowlsby   Two issues I see: That big yellow wire on the ign...   Mar 29 2015, 10:27 PM
91422.7   Two issues I see: That big yellow wire on the ig...   Mar 29 2015, 10:44 PM
SLITS   The item in your last image is the AAR (auxiliary ...   Mar 30 2015, 06:52 AM
91422.7   I forgot the wiring harness that runs from the sta...   Mar 30 2015, 09:11 AM
Jeff Bowlsby   Lose the relay gobbledegook. Hook it up correctly...   Mar 30 2015, 09:34 AM
91422.7   Lose the relay gobbledegook. Hook it up correctl...   Mar 30 2015, 10:29 AM
Kansas 914   Lose the relay gobbledegook. Hook it up correctl...   Mar 30 2015, 10:38 AM
SLITS   I disagree with you two experts. The relay takes ...   Mar 30 2015, 11:01 AM
Elliot Cannon   I agree with SLITS (did I just say that)? I'v...   Mar 30 2015, 11:09 AM
Jeff Bowlsby   OK you guys....I never professed to be an expurt i...   Mar 30 2015, 12:27 PM
isdyl   Hi - Sorry to resurrect an old thread but I'm ...   Nov 8 2018, 04:32 AM
barefoot   Hi - Sorry to resurrect an old thread but I'm...   Nov 8 2018, 06:53 AM
dr914@autoatlanta.com   usually if there is a delay the ignition switch ma...   Nov 8 2018, 08:48 AM
isdyl   Great diagram - Thanks!   Nov 8 2018, 08:08 AM
isdyl   Thanks - I'll check that out too. Regards Dyla...   Nov 8 2018, 11:42 AM
isdyl   Hi - no it's not the ignition switch as I took...   Nov 9 2018, 05:41 AM
isdyl   Ok, so I cleaned up the two large plugs on the pla...   Nov 9 2018, 11:20 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 8th January 2025 - 09:56 PM
