renaultc |
Newbie ![]() Group: Members Posts: 13 Joined: 18-February 13 From: Regina, sk Member No.: 15,548 Region Association: Canada ![]() |
Good Morning World,
My name is Chuck and I've been lurking on here for some time. I have a 1974 2.0L that I purchased a couple years ago from Craig at Camp 914. Very solid car but did leak a bit of oil (what 914 doesn't lol). Well the oil leak did start to become an issue with the significant other and the time has come to pull the engine and begin the teardown/rebuild process. More on this below. The car does appear to be stock with the exception of EMPI carbs that were added a few years back, along with an EMPI distributor MSD ignition, coil and tach control unit have been added to facilitate the Carbs. I do have most of the D-jet components and considering re-using. The previous owner said he was chasing a leak some where and couldn't cure the high idle and made swapped to carbs. Other Mods that have been done were the addition of J-West shift kit, conversion to 5lug, knock off Fuchs(wish I could afford the real ones), Knock off's will have to do for now. From the pics you will see that the oil leak is primarily around the cylinders on the underside and at the cylinder heads. Not sure if the sealant used or was applied properly during a previous rebuild. As you will note in the pics the heads do appear to be in really good shape along with the cylinders. My plan is to re-use the heads and if these cylinders are stock I'd like to bore to 96mm and install KB pistons/hastings rings. Change the cam to a suitable cam once I decide on which Fuel delivery system I want to use. If not stock d-jet then I'd like to get my hands on a set of Italian webers. if the crank and rods are good and no line bore is required then all these components will be re-used in my build. I know questions and comments will be forthcoming and appreciate all comments from everyone and any advice you'd like to provide ![]() ![]() ![]() ![]() ![]() 323] ![]() ![]() ![]() =495327] ![]() ![]() Attached image(s) ![]() ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
if indeed it was rebuilt it seems to me there may have been water in the valve cover???
Is that rust on the valve train? Good for you doing a rebuild. For you to take note of, the CHT bung should be on the number 3 head port, next to the spark plug hole , near the rear of the motor. That will help you keep the heads oriented properly as you go to clean them and get them ready for inspection....that tape wont last long... Measure what you have for piston diameter....might be worth keeping that setup...never know. Rich |
renaultc |
if indeed it was rebuilt it seems to me there may have been water in the valve cover??? Is that rust on the valve train? Good for you doing a rebuild. For you to take note of, the CHT bung should be on the number 3 head port, next to the spark plug hole , near the rear of the motor. That will help you keep the heads oriented properly as you go to clean them and get them ready for inspection....that tape wont last long... Measure what you have for piston diameter....might be worth keeping that setup...never know. Rich Hey Rich, yup that's rust on that bank. The vacum line was disconnected from that cylinder and ill assume water got in through there and rusted it out. Im more than likley going to find a good set of 1.7l rocker arms and go with 911 swivel feet. This is my first ever build so im taking my time and going to learn as I go. Im might need to farm out part of the build as I dont have the skill or tools to setup or properly cut pushrods, balance the whole assembly or do head work. For me the tear down is good experience and gives me the knowledge of how all the components work and if I do need to do servicing after its all back together then I have an uderstanding of where components are. |
Lo-Fi Version | Time is now: 1st July 2024 - 02:27 AM |
