> Rebuilt engine 2.0 year 76, Questions befor installation
DavidSweden
post Apr 3 2015, 01:44 PM
I have finally completed my engine rebuild which has not been without problems and took much longer than planned. It was also expensive, I thought that a VW motor would be a cheap option but I guess I was just kidding myself. You will see that I have installed the 74 heat exchangers and removed the smog stuff
Anyway the engine is sitting on a pallet and will be installed tomorrow. I have some newbie questions which I hope someone can help me with.
1. In the engine bay near the hell hole there is a green/black wire coming from the wiring harness, is this for the temp sensor mounted on the underside of the engine?
2. I will do the static timing should this be for TDC or a few degrees before?
3. Is there anything I need to be aware of before installing or is it just a case of bolting the motor in position?
4 Once the engine is fired up should I run at 2000 rpm and set the timing to X degrees BTD or what is the best procedure?
5) I think I need 5 quarts (3,5l) of oil is this correct?
6) How do I get the throttle cable up to the overside of the engine?
Thanks
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1428090298.1.jpg)
Dave_Darling
post Apr 3 2015, 08:33 PM
914 Idiot
QUOTE(DavidSweden @ Apr 3 2015, 12:44 PM) *
Yes.
TDC will work for starting the motor.
20 minutes at 2000 RPM to break in the cam. Timing is set to 27 degrees BTDC at 3500 RPM after that.
I don't think you have that conversion right. Anyway, 4 quarts is good.
It goes through a hole in the engine tin over on the right side.
--DD
DavidSweden
post Apr 4 2015, 12:19 AM
Thanks Dave
- Lo-Fi Version Time is now: 27th December 2024 - 12:30 AM
