> Subaru Engine Swap, It is now the 1971 Ivory Car
AndyB
post Feb 27 2015, 12:39 PM
The Governor is watching me
So I am finally doing the Subaru drive train conversion. I picked up my donor car from a salvage auction for $200.00. Yes the entire car and yes it does drive and run. With that being said I am still looking to those more knowledgable in the Subaru arena. The car is a 2002 Impreza Outback Sport. It has a 2.5l in it and over 200k on the odometer. My plan is to tear the engine down and rebuild it a little more then stock. I have no intentions of dropping in a turbo, that's for another one. Who are some reliable sources for performance parts other then all the usuall Subaru upgrades that would be done on a Subaru. I am concerned about the cooling aspect of the engine. I would like to know what people are using for radiators. Thanks.
Chris H.
post Apr 3 2015, 10:22 PM
You're thinking about doing an automatic trans? Not the Subaru AWD auto from the SVX right? It's too long and weighs a TON. The gearing is also very poorly matched to the engine. You'd probably want to find a 2WD Subie trans (pre-1997ish).
mgp4591
post Apr 3 2015, 10:46 PM
QUOTE(Chris H. @ Apr 3 2015, 10:22 PM) *
And it looks like all 2WD automatics from 92 on in all Subarus were 4EATs. I pulled my 2WD tail section from a 93 Impreza- it bolted right on to the SVX trans along with the internal shaft, gear and bearing that eliminates the electromagnetic AWD assembly. It was a high point of my day when I found the part and it fit, all for 40 bucks!
Chris H.
post Apr 4 2015, 07:24 AM
QUOTE(mgp4591 @ Apr 3 2015, 11:46 PM) *
VERY interesting. Thanks for the info! I was planning an automatic myself at first. I've stopped a few people from saying "I'll make it fit" and "I'll live with the weight", but it's a lot more than that as you have learned. Sounds like you have it all figured out. Nice work. Never thought of using the SVX trans shell and stuffing new internals in it.
The 4EAT was definitely the trans used for all applications until ~2003 when they switched to a 5 speed auto. Work horse. Ford used it too. It's still made today. The 5 speed auto is a very complicated beast BTW that has too much electronic wizardry to convert to 2WD. The computer moves the power around to each wheel pretty regularly so Ian and I figured it might not work at all, or would get weird when the tires slipped because it would try to send power to a wheel that was not there. Plus it's even LONGER.
You gotta update your thread man! (IMG:style_emoticons/default/poke.gif)
Andy,
On radiators, Bob (BIGKAT) had a very nice fluidyne radiator in his car that was extremely compact. Seemed like it was about 10" high. We drove it quite spiritedly for a while and the needle never moved at all. Very nice rad. I agree with Kent though, look at everyone's and then do your own based on the ideas you get. Although pricey, it's been said many times that the Renegade kit is proven and will definitely work, so if you just don't want to deal with the fabrication you could go that way.
FYI I have speedhut gauges and really like them, but also sort of miss my stock ones. I picked the speedhut ones because I had a few problems:
- converting to 6
- needed a way to get speedo signal
- wanted a quad gauge
I was convinced I wanted a GPS speedo so rationalized the cost of the speedhut speedo easily and it was all downhill from there. Since you don't have to convert your tach signal from 4 to 6 the cost of staying with stock gauges is much lower for you.
Scarlet75   Subaru Engine Swap   Feb 27 2015, 12:39 PM
CptTripps   Oh man....there are no shortage of options here. T...   Feb 27 2015, 01:19 PM
Scarlet75   Oh man....there are no shortage of options here. ...   Feb 27 2015, 02:45 PM
mepstein   Oh man....there are no shortage of options here....   Feb 27 2015, 03:12 PM
ThePaintedMan   Not to hijack, but before you order the one from R...   Feb 27 2015, 03:21 PM
Scarlet75   Not to hijack, but before you order the one from ...   Feb 27 2015, 07:05 PM
DBCooper   Huh. Mine's been in there for eight years now...   Feb 27 2015, 06:19 PM
Scarlet75   Huh. Mine's been in there for eight years no...   Feb 27 2015, 06:58 PM
Scarlet75   Huh. Mine's been in there for eight years no...   Feb 27 2015, 07:12 PM
DBCooper   DB are you running a turbo? Yes. When I bought...   Feb 27 2015, 07:37 PM
Mike Bellis   Most likely you could use the radiator from the do...   Feb 27 2015, 07:08 PM
Scarlet75   Most likely you could use the radiator from the d...   Feb 27 2015, 07:10 PM
Mike Bellis   I knew you would weigh in Mike thanks. And are we...   Feb 27 2015, 07:30 PM
Scarlet75   I knew you would weigh in Mike thanks. And are w...   Feb 28 2015, 06:55 AM
JRust   The nice thing with a NA suby is they are easy to ...   Feb 27 2015, 07:32 PM
76-914   George, if his radiator leaked at 90 days then he ...   Feb 27 2015, 09:29 PM
Scarlet75   George, if his radiator leaked at 90 days then he...   Feb 28 2015, 06:54 AM
76-914   George, if his radiator leaked at 90 days then h...   Feb 28 2015, 10:29 AM
Scarlet75   So like many things this has now turned into a sin...   Mar 11 2015, 04:50 PM
mepstein   What car is getting the work done? Pics?   Mar 11 2015, 04:58 PM
Scarlet75   Sorry about that. Its Scarlet, she has been a nobl...   Mar 11 2015, 04:59 PM
mepstein   I'm surprised. I thought you had a strong runn...   Mar 11 2015, 05:22 PM
Scarlet75   I'm surprised. I thought you had a strong run...   Mar 11 2015, 05:35 PM
Scarlet75   I already have the wheels which are 17 x 8's P...   Mar 11 2015, 05:45 PM
mepstein   I know Ian at coldwater is really busy right now b...   Mar 11 2015, 08:18 PM
AndyB   I know Ian at coldwater is really busy right now ...   Mar 12 2015, 04:21 AM
R_u_dd   Did your donor come with a 5mt tranny?   Mar 12 2015, 08:27 AM
AndyB   Yes I searched through what seemed like a thousand...   Mar 12 2015, 08:29 AM
R_u_dd   Yes I searched through what seemed like a thousan...   Mar 12 2015, 01:15 PM
AndyB   I am going to run the Subaru instruments on my car...   Mar 12 2015, 01:29 PM
Amenson   I am going to run the Subaru instruments on my ca...   Mar 12 2015, 01:55 PM
R_u_dd   I am going to run the Subaru instruments on my c...   Mar 12 2015, 06:42 PM
rnellums   I wanted to keep the stock gauges on my car, just ...   Mar 12 2015, 07:54 PM
914forme   Yep I love this idea, I would also like to add...   Apr 3 2015, 05:38 PM
AndyB   How did you do that? Those are incredible.   Mar 22 2015, 02:16 PM
AndyB   So I am still in the tear down phase of the rebuil...   Mar 22 2015, 02:21 PM
rpg5553   My radiator and ECU option I picked up a complete...   Mar 22 2015, 03:14 PM
AndyB   My radiator and ECU option I picked up a complet...   Mar 23 2015, 10:21 AM
AndyB   Do you have any pictures of your cooling set up? I...   Mar 22 2015, 05:53 PM
rnellums   How did you do that? Those are incredible. Send...   Mar 22 2015, 08:41 PM
AndyB   Ok to the water cooled 914 crowd, can you please s...   Mar 23 2015, 09:55 AM
76-914   Ok to the water cooled 914 crowd, can you please ...   Mar 31 2015, 01:41 PM
mgp4591   Not meaning to gripe too hard, but not fair! T...   Mar 23 2015, 10:26 AM
AndyB   I wont disagree with you, however Ronnie G is the ...   Mar 23 2015, 10:30 AM
ruby914   Hi Andy, Something I have been thinking of for a l...   Mar 31 2015, 01:04 PM
AndyB   Hi Andy, Something I have been thinking of for a ...   Apr 4 2015, 05:13 PM
mgp4591   I was wondering if all the twists and turns in the...   Apr 3 2015, 10:00 PM
Chris H.   You're thinking about doing an automatic trans...   Apr 3 2015, 10:22 PM
mgp4591   You're thinking about doing an automatic tran...   Apr 3 2015, 10:46 PM
Chris H.   You're thinking about doing an automatic tra...   Apr 4 2015, 07:24 AM
mgp4591   I've already pulled the tail section from a 2w...   Apr 3 2015, 10:38 PM
rnellums   Yep I love this idea, I would also like to ad...   Apr 3 2015, 11:50 PM
mgp4591   Thanks for the kind words but I am FAR from having...   Apr 4 2015, 01:55 PM
Chris H.   I'm on phase 2, which means the engine comes b...   Apr 4 2015, 02:42 PM
AndyB   Yeah I would of used the original but the deer had...   Apr 4 2015, 03:13 PM
AndyB   Ok so much has happened since my last post. I went...   Apr 24 2015, 06:48 PM
AndyB   The passenger long Drivers long   Apr 24 2015, 06:58 PM
AndyB   Last time it was on the road.   Apr 24 2015, 06:59 PM
AndyB   Don't do it Mark <_<   Apr 24 2015, 07:01 PM
76-914   This is donor car or your Suby conversion car?   Apr 24 2015, 09:20 PM
AndyB   This would be the conversion car. It was a tough c...   Apr 25 2015, 04:39 AM
AndyB   So lots of progress today. She still isn't on ...   Apr 25 2015, 07:32 PM
20 User(s) are reading this topic (20 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 12:38 AM
